Pole Anchor Bolts Pattern is set wrong in base
brantmacga
Señor Member
Georgia
Former Child
Yeah, they installed those incorrectly that is why they failed. :roll:
In our case we had to drill 1" holes 18" deep and install 3/4" threaded rods into those holes with epoxy. They will never come out.
i've done the same.
used something called C6 epoxy. that stuff sets harder than concrete.
plumb bob
The only solution I have seen used is Iwire's. My company was contracted to replace 5 existing light poles with poles that had a different base design. Engineer's solution was to cut bolts, redrill base, and epoxy new bolts. We only ended up having to cut one of the 4 bolts, the pattern was close enough that we could reuse 3 of the originals. May save the OP some time and money if he can do the same.
