Eddy Current
I know there is galvanized, aluminum, copper, tinned copper. Should i know of more?
Does mixing them cause oxidation?
Oxidation is caused by being exposed to air (rust is the oxidation most people easily recognize).Does mixing them cause oxidation?
There is also brass, bronze and stainless steel.
To do what?I know there is galvanized, aluminum, copper, tinned copper. Should i know of more?
Oxygen causes oxidation.Does mixing them cause oxidation?
Brass, Cadmium coatings ...
There are many natural and probably even more man made alloys out there. Every type of metal has its own charactristics that makes it good or bad choice for specific applications. Most metals are good conductors of electricity but other than that, what exactly are you asking?
With a name like Eddy Current, you just might have a passing interest in steel for laminations.....
Which ones do i need to know about. I know its not good practice to mix dissimilar metals.
What is electrical steel used for?
What is the application of the metals in question?
For instance, the construction of conduit.
Or are you asking what conductors are made of?
Or are you asking what connectors are made of?
Or are you asking what a bender is made of?
Also, it's not quite clear as to what you mean by 'know about'. Do you mean just realizing they exist or are you looking for other properties as well? Dissimilarity would be one property. K factor another. Atomic weight, types of alloys, applications, melt point, etc.
And my wit was wasted.....:weeping:The purpose is to reduce eddy currents.
It was just a general question, working in the electrical field which metals do i need to know about.
I guess it would be helpful to know what lugs are made of and what different types conduit are made of, say for example emt.
