jumper
- 3 Hr 2 Min from Winged Horses
I disagree with you assertion that voltage testing should not be considered examination. Voltage testing is the epitome of "Examination". I agree with Kwired. The key difference between a wall switch and an A/C disconnect IMHO is the term "Likely to be examined while energized". My opinion is that a disconnect is the most likely location for voltage testing while servicing an A/C unit while a wall switch would not be a likely place to test for voltage for servicing a luminaire.
JMHO,
Chris
Ditto. First place I check before I start pulling the HVAC covers off is the disco. Rule 1, check your source.
