jaggedben
- Northern California
- Solar and Energy Storage Installer
What would cause a receptacle to read 120V hot-to-neutral but a varying voltage between 20-50V hot-to-ground? I would assume a high impedance connection to ground, but could it be something else?
Even more mysterious to me was that my power tool battery chargers (Makita 18V) would not operate properly when plugged into this receptacle. :blink: Both of them gave 'bad battery' indications. When it happened with two different chargers and two different batteries I realized it was something about the supply from the receptacle. The chargers worked fine later on at a different site. The battery charges do not have a third prong, and it does not seem right that a bad ground connection would affect them. What would the relationship be, if any, between the voltage readings and the battery chargers not operating correctly? :?
Thanks in advance for your speculations.
