goldstar
- New Jersey
- Electrical Contractor
I have a customer who lives in a house that has all electric 240V baseboard heat.  Whoever built this house, in their infinite wisdom, decided to use low voltage thermostats wired back to a bank of switching controls.  The brand name on the control is Honeywell Aqualink but I don't believe they make this equipment anymore so I'm trying to find a replacement.   There are 2 separate 5-zone switching enclosures  located adjacent to the main breaker panel and there are 8 separate 20 amp, 240V circuits used for the heating units. There's also a 24v transformer built into each switching unit.  After doing some investigating I found that each of the heating zones has one side of the 240V circuit wired directly to it and the other side switched through one s/p zone of the control (I know it sounds weird but please bear with me).  When a zone calls for heat, 24VAC is sent to a carbon resistor of a specific zone.  When that resistor heats up it heats up a spring-loaded contact (similar to a reed switch) that will close when hot, sending the second phase of the circuit to the heating unit.  When the temp in the room is satisfied the 24VAC is removed, the resistor cools down and the circuit opens.   Some of these zones have now locked up and heat all the time, thus my reason for finding replacement controls.
As far as I can tell these units work similar to Jandy pool controls. I would use a Jandy control but my only concern is that the small relays wouldn't handle the current load required by the baseboard heating units. I'm thinking of building my own switching controls by using Potter-Brumfield heavy duty (25 amp rated) 2-pole relays w/ 24V coils. If anyone has a better idea or knows of control equipment I can use would you please point me in the right direction ?
Thanks
Thanks
