- Tennessee NEC:2017
- Semi-Retired Electrician
Lets say you have a junction box and it is being used for a central feeder/connection point. In the box you have your power in, light feed & switch, GFCI line and GFCI load, and feed to other receps from the GFCI load. What would happen if instead of taking the neutral from the GFCI load straight to what it feeds you tied all the neutrals together in the jb?
Would the GFCI work? This would all be one circuit, not a MWBC.
