To all you EE's out here:
I am doing a little research on transformer loading above nameplate rating.
I am looking for formulas to figure out the cooling time required for xformer loaded above nameplate.
In this interesting thread i stumbled across a interesting quote :
http://forums.mikeholt.com/showthread.php?t=128639&highlight=mount+overload
I am wondering where I find some of these formulas?
(I have checked through some MFR data sheets, and looked through several manufacturers specs on sizing transformers and found some interesting stuff short of a formula.
I have glanced at a few dusty engineering text books as well.)
I found an article here however it is $225.
Thanks in advance for any formulas,tips, links or ideas etc.
jim dungar said:Heat build up is what causes all transformers to fail (excluding short circuits). Theoretically, you could overload a transformer by 200% for 12 hours then turn it off for 12 hours, and it would last for its normal life expectancy. In reality it takes longer for a transformer to cool down then it does to heat up, so the period of loading would more likely be 200% for 8 hours followed by <50% load for 16 hours. There are formulas to figure out the amount of cooling time required based the ambient temperature and the actual loading profile.
