BU bulb in a base down socket
cizzle21p
Hereford, TX
Why does this matter? We had to use a BU, PS 400W bulb in a lighting fixture that has base down socket. Any info would be great, just curious as to why it matters.
Two things- heat dissipation and light center. Most base-up lamps have less distance from the light/heat producing part to the end of the envelope and correspondingly have a longer support structure to the base. When you burn a BU as base-down, the top of the envelope will get hotter and usually fail faster.
An offshoot of that is that the light center may be in a different place, not in the center of the reflector, so the fixture will produce less usable light.
cizzle21p
Hereford, TX
Up light Fixture
Up light Fixture
This light fixture shines down over a roadway at about a 45 degree angle. The socket is a base down fixture though. We had to use a BU bulb because that is all we have in stock and are unable to get them immediately. I know its not an issue, and assume the lamp would work fine ( for a shorter duration than expected). I was just curious about the details as to why the bulbs are designated for different sockets. Thanks for the info.
