K8MHZ
- Electrician
Sorry.
It is not convincing.
The problem is lightning has tremendous power but only limited energy due to its very short duration.
Because of it, lightning can not melt any 'thick' metal such as a 2/0 conductor.
First, 2/0 isn't that thick, only about 1/2 inch. Additionally, it will be stranded. I personally haven't seen 2/0 melt, but I know it will. I have seen lightning melt glass. My friend has a pane of glass with a 2 inch hole melted through it by lightning. I have seen lighting split pine trees that were more than a meter in diameter right in half. I have seen a video where #6 on a power pole didn't just melt, it vaporized in a flash. Lightning also melts sand together in the dunes nearby. I have shown this before, the result of the molten glass is called a 'fulgurite'.
From Wiki - Click here for pics.
Fulgurites (from the Latin fulgur meaning thunderbolt) are natural hollow glass tubes formed in quartzose sand, silica, or soil by lightning strikes.[1] They are formed when lightning with a temperature of at least 1,800 ?C (3,270 ?F) instantaneously melts silica on a conductive surface and fuses grains together; the fulgurite tube is the cooled product.[2] This process occurs over a period of around one second,
I can understand your doubt about flat conductor. I remember the first time I saw it used for lightning protection and I thought someone was either very stupid about lightning or playing a joke. No way did I think that thin, flat strap would conduct lightning without fusing open.
My mind changed when I did some study. My resources of study were not just from the electrical side of things. I have been doing volunteer work on and off for the National Weather Service for 15 years. In order to do so, we have to have storm training. A good part of that training is centered around the behavior of lightning. Since I am a ham radio operator, I also get to see how towers are installed and protected on a scale larger than all but the most experienced sparky or electrical engineer.
You never did tell me what your exposure to real lightning is. It seems all you are doing is guessing that 2/0 stranded wire will carry a bolt of lightning without fusing open. You need convincing that flat strap is the way to go, like I did many years ago, and you may not get that if you live in an area that does not have to contend with thousands of lightning strikes each season.
