Daniel malack
 - Amissville, Virginia USA
I have a meter base approximately 15' from a transformer, a 600 amp fused disconnect connected to meter base, 400' run to residential building panel has 3 200amp breakers, three 200amp runs to panels inside the home.  I want to use direct buried cables for the 400'run can I just run 3 wires or do I have to run 4? My inspector is way out in the country so I would need code references.
