DataCenterGuy
- New York
Contractor used double-hole lugs but attached with only one bolt.  Manufacturer won't start UPS, claiming a Code Violation.  Contractor disagrees.  Obviously, it would make sense to use two bolts, but the best I can find in the Code is 110.14 (A): "Connection of conductors to terminal parts shall ensure a throoughly good connection - etc."  Contractor says single bolt is tight and good enough.  Engineer didn't spec double-hole lugs.  Any Code or other backup for this stupid controversy??
