Eddy Current
I haven't got around to studying motors yet, but i was told today that motors don't arc. I thought the brushes would arc a little, kind of like looking into a drill.
Depends on the type of induction motor.Two different motors. Motors with brushes, yes. AC induction motors, no
Slightly off topic but speed control with wound rotor motors are still alive and well.Older variable speed motors that use a wound rotor and rheostats mounted through slip rings do as well.
So AC no DC yes? What about a pretty large motor that would run a conveyor belt line?
I noticed a lot of the drills now are brush less would they still arc?
Not true.
If motor has brushes to supply current to a wound rotor it will have arcing at the brush contact points, true for both AC and DC supplied motors of this design.
Any motor that has an internal switch that operates at a predetermined speed (like to open a starting component) will also have arcing when this switch makes or breaks contact.
I didn't think about the switch but what about the brushes on an "brushless" drill?
What brushes on a brushless drill?
I don't think you have to know anything about motors to see a conflict in what you asked.
