gadfly56
- New Jersey
- Professional Engineer, Fire & Life Safety
Cadmium coatings?
Where? Cadmium is a toxic metal. With the exception of specialty platings for use in the aircraft industry, cadmium plating has been replaced with zinc dichromate or nickel.
What many assume is cadmium plating on bus bars is likely nickel or tin.
What, you never cut a piece of Unistrut? It isn't offered anymore, but I have a PDF copy of the 2009 price book which lists cadmium plated as an option for Unistrut. IIRC, if you didn't specify, this was the default you'd get. It had a gold color to it, which is still availble with their phosphate-based coatings.
