- NE Nebraska
- EC
Does Chicago prohibit PVC raceways?
Maybe steel workers union is behind this
The State of Minnesota Department of Labor and Industry Electrical Licensing and Inspection is the Statewide AHJ and, as such, uses the un-amended NEC.Our AHJ has not allowed 14 gage romex for decades. The Ordinance keeping the wiring method as prohibited is now being considered for removal. The pros and cons are being weighed in detail. The question is: Does your AHJ allow 14 gage romex wiring?
and can you share your location, State, county, city?
At an NEC class I had a pair of inspector sorts tell me that I obviously did not care for my family because the 14 wire would catch fire. Truth - that's what they said. And they actually looked like they believed it to be true.:happyno:
I am surprised that they didn't tell you, "Just cut some of the stands off the #6 and poke the rest in the hole in the back of the receptacle."So I asked: If I want to run a 120v, 20A circuit 400 feet to an outbuilding for a singe receptacle - maybe #6CU. I likely would put in a jbox with terminal blocks and pull a #12 tap off to the receptacle, and maybe even another #12 tap to a lighting outlet. Tell me, how would you connect the #6 to a receptacle?
ice
:lol:14 AWG is same thing detonation cord is made of![]()
At 3 watts/SF #14 will cover 600 SF, #12 will cover 800 SF. Only certain size houses will have fewer home runs, fewer circuits. For example a 1601 SF to 1800 SF house will need 3 #14 circuits or 3 #12 circuits. But an 1801 to 2400 SF house will need 4 #14 circuits.
