1. All exposed metal must be grounded. If rack is, then panel frame must also be.
WEEB lugs on both will be great.
I trust rails are aluminum if contacting aluminum panel frame.
(grounding of panel required by CODE....... and practical reasons, too: Anodization of aluminum, often clear and invisible, effectively isolates panel frame from rails. (I've tested this.)
2. I cannot answer your last Post.
