It is if there is severe flooding issues:happyyes: Of course the occupancy is no longer just a dwelling it is also a marina or boat yard.
Then it would need GFCI! :lol:
The rules concerning physical damage are the same, so there is no advantage in using MC. I see no problem with running NM.ANOTHER question about this same structure. Part of it will have walls on both sides of the framing studs, so I know that I can run NM (romex) there, BUT other parts will be open on one side, so I plan to run EMT.
The area between floors is 2x8 framing. Would this area, be considered "not" subject to physical damage, so therefore would it be permissible to use NM or Metal Clad in this area?? Due to the type of framing done, it is not conductive to install EMT there. Thanks again--------
