listed potting compound
rbwsparky
Sewickley,PA
I am working on a new pool installation and need to know what listed potting compound to use for pool light niche. Inspector's check list state..Where rigid nonmetallic conduit is used between the wet-niche fixture and the junction box a No. 8 insulated copper conductor shall be installed in the conduit, and its termination in the forming shell shall be encapsulated in a listed potting compound. {Section 680-20 (b) (1). A 3M item number would help.
Good Eye! I've been out of school WAY too long. Just goes to show, you learn something new Every Day:) Thanks Brother
Not a problem, don't feel bad, the pools I wire, the pool contractor installs and light and doesn't use the compound either, his statement is that, its too hard to replace a light with without pulling the bond wire with it.... I actually had to shame him into doing it because I mentioned how even his competitor uses a potting compound, and that guy is a REAL hack... :) sad world we live in. :(
Not too proud to learn from others. If you can help a friend or neighbor, the world will be a better place for ALL of us:)
In all my years, i've found pride is the hardest thing to swallow for some... Inspectors included, I just don't see why a learning process has to be so hard. Of course, I'm here to educate myself to begin with, so thats probably half the battle, the "WANT".
