120601-0920 EDT
Besoeker:
It is common knowledge, based on prior analysis, that the minimum impedance of a series resonant circuit is at resonance. Thus, maximum current from a constant excitation voltage is at resonance, and maximum power in the series resistance of the equivalent circuit is at resonance. You do not need to assume resonance, you know resonance is required.
Yes, I know all that. I'm simply pointing out that part A appears to ask the question without any prior reference to maximum power.
Maybe it was somewhere in part of the question not posted.
