It seems simple to me to measure the voltage across the contact which represents the voltage drop as a result of contact resistance. The more difficult part would be to get a current reading at the same time. One couldn't get a more accurate value other than in actual operation conditions which may change everytime the contact is opened and closed which most likely would be trivial at best.
With these two figures you can calculate a real contact resistance. If you want to record the ambient temperature, humidity, the type of contact material and all that mundane stuff that doesn't really make any big difference include them in the documentation which will probably smoke those that are asking for the contact resistance but really are of no consequence. I have had those ask for measurements and documentation when they didn't have the slightest clue about what they were asking for.
In reading these replies I must say it is interesting how something so simple can be turned into such a big ordeal.
