Had a customer call telling me that his electric motor for his boat hoist will only lift the boat about 2/3rds of the height it should. Says the motor gets to that point and the breaker trips. Tells me that it's wired for 120V and that its about 300' from the panel in the garage. He had a guy come over from a local marina and he told him that the motor would work fine if it was wired for 230V. Marina guy must be thinking that voltage drop is causing the problem. Owner tells me that this set up has worked fine for several years prior to this summer at 120V.Any thoughts?
