Gaffen99
- new jersey
I am looking at a print and keep seeing ACR next to the GFCI. Can someone tell me what this means?
In what situation would you connect a GFCI breaker to a HVAC load ? Two pole GFCI breakers
are used to protect pools, hot tubs, spa. Single pole used for kitchen, bath, outdoor
recptacle protection. I don't get it ?
If for some reason it was cord and plug connected and used a 15 or 20 amp 125 volt receptacle in areas where GFCI protection is required ...... otherwise I dunno.
An example may be a window a/c unit that is ina room with a hot tub and the receptacle is in the distance from a tub to require gfci
