brian john
- Kilmarnock, Va
- Retired after 52 years in the trade.
On a 480-Delta - 208/120 Wye Transformer back-fed 208 3-phase on the wye primary, no neutral but the neutral bond was left intact. The neutral bond in one case was heat damaged but still connected in another circumstance burnt open.
I THINK, the secondary current (Delta H side) was single phase 480 (unit heaters), so loads were not always balanced.
As always any input would be appreciated.
Also from a proper terminology stand point, in this case is the 208 considered the primary, my contention is it is? I have had this discussion more than once.
