Hello,
Sometimes I have to measure 440 volts for parking lot light work. My meter's range does not go up to 440 volts, though I can read 277, which is good enough to measure each phase to ground. Trouble is, because the lights are ballasted, and ballasts provide a continuous path between two phases, when one phase quits it's conductor still shows 277 volts to ground because of the way the multiple ballasts on a pole are wired together. Ideally I would be able to determine that both phases are working by measuring between them; if there's 440 volts then both phases are working, and if there's zero, then one of the phases is not working, (and I'm reading the same phase twice). But my meter doesn't go up to 440 volts. I don't need to know the exact magnitude of the voltage between phases; for the purpose of determining that both phases are working it would suffice to know that the voltage between them is significantly above 277. Is there a simple, safe, and inexpensive tool I can use to test the phases?
Thanks,
Tom
Thanks,
Tom
