I am following on from some earlier discussions earlier this year.
It is actually easy to provide 120/240V from a 3-phase source, in which the voltages are correct and the loading can be close to 100% and spread evenly across all three supply phases.
1 ph loading of 3 ph transformers. [ previous discussion thread ]
" As I recall from past training I believe that a 3 ph Y connected transformer can be loaded to 58% with single phase loads if there are no 3 phase loads. " .. And
" Providing 120/240V supply with 3 single phase transformers. " etc.
There is an easy way to provide 120 / 240V from a 3-phase supply, using a simple, but special transformer arrangement that can be done with a special 3-phase transformer if available, or by using three standard, off-the-shelf readily available single phase transformers. Their primaries being connected in the typical or standard way. Their secondaries being connected to each other in a special way, so as to provide two 120V outputs, L1 & L2 relative to Neutral and with 240V between L1 & L2. These connections are easy to do, but the electrician does need to know which connections to make. This is explained in a paper ?Transformer for 120-240V from 3-phase? : https://dl.dropbox.com/u/88752751/Transformer for 120-240V from 3-phase - Detailed A2.doc
