newservice
"Scotchkote" is a good product to use on nicks. If it has been working for 2-1/2 months since the excavation they did not pull anything apart but still could have done some damage and even taped it up or something thinking they would be ok with that.
The fill was very rough, no 2 inches of sand in the bottom of that trench. Am thinking now put it in pipe. Also, in the splice box that Ill be putting in, what type of connectors there? Those connectors use a sleve and are rated forthe gauge wire Im using, the 4/0 goes directly in with no sleeve and the 2/0 you cut the sleve on the right ring and use that, inside is filled with antiox and the connector is rated copper or al. Thanks to all for the feedback very useful.
