Open Neutral
 - Inside the Beltway
 - Engineer
I think this is a good point. I have started seeing harmonics issue showing up in traditionally residential areas too, in the same way Besoeker did; someone wants harmonic mitigation for a VFD and to do it right, you need to know from whence you start. I've been surprised by the existing THD when I get there, even though it doesn't appear to be an "industrial" area where one would expect it. Could be the cumulative effects of all the CFLs, electronic ballasts, PC power supplies, big screen TVs and "energy efficient" appliances that all have SMPS or VFDs on them..
WhatHeSaid. There seems to be more and more crapola on the power grid. With SMPS's on everything from shavers to microwaves to laser printers, we're not in Sinewave Kansas anymore, Dorothy. And then there are the switched solar array inverters.
