GerryB
- woodbridge, ct. USA
A detached gararge new wiring, I have one circuit. I fed a receptacle, GFI. From the load side I ran a cable to an outside plug, another to a switch box. From the switch box to another plug. The switch is a 3-way where I carried the feed and neutral through from the other end. I had all the neutrals spliced together and the gfi would pop. When I spliced the neutrals separately(plug to plug, light to light) which I usually do if it's two different circuits, it was ok.
