Cow
- Eastern Oregon
- Electrician
What do you guys use for a small tugger rope? We've got some pretty good size rope we use in conduits, say 2" and larger, but it would nice to have something for the smaller conduits as well. We're using mule tape right now. Right now we're doing 3 identical pulls, 1" pvc 400ish feet long with 3-4's and an #8. We used BRAND NEW 1800lb mule tape on the first pull, worked alright, aside from the fact it wraps over itself on the tugger and wants to keep tugging even if you let go. Second pull, 14' from coming out the mule tape breaks. FORTUNATELY, we were able fish the end of the mule tape back out of the conduit, tie a knot in it and eventually get the wire out. The wire came out dirty on this pull so it's obvious that caused the break. Swabbed back and forth, and then revacuumed the third conduit out for the pull tomorrow. Hopefully it'll go like the first pull.
I think it's time I try and get the boss to spring for something made for a tugger. A coworker mentioned something called Amsteel, he's seen the power companies use it, but he said it's expensive. The tugger we're using right now is 4000lb rated.
Thanks guys.
Thanks guys.
