I am trying to increase the amp reading on a motor that is drawing only.6 amps with the load on my amp meter. The reason being is that i am using a electronic overcurrent relay that has a 1amp minumium setting and at .6amps the motor won''t register on the relay. Any ideas on how to increase the current reading to fool relay into thinking it has more of a load. Using a ct built on the relay. motor 480volts 3/4 hp 1.1amp. Thanks for any input.
