Event Production power distribution, I want to do it right.
mattvivsound
New member
In the past year or so my small business (sound, event production) has grown and now I need to get power correctly from multiple sources. A year ago, I was able to plug my PA system into a pair of 15/20 amp/120v outlet and be fine with that. A couple of the places have a 14-50 Range plug for me to draw power from and I built a small distro panel that took the 14-50 power and split it into 6 5-15 20amp outlets.
Now that my small company is growing and I am getting more exposure (higher profile gigs). With that I need to update my power situation so it is Professional and doesn?t raise any eyebrows. So I am in planning phases of rebuilding my power system.
Sometimes I have wall outlets for power and then other times I may have 3-Phase 208v to plug into and I need to be able to cover everything in-between. With that in mind, all my racks are wired with Edison/5-15 plugs.
I am looking at having 2 PDs built; a Cali Plug (120/240v 50amp, CS63##) and then a 3 phase 5 wire in.
- Small Distro: I am looking at a Rack Box with a CS63## in/thru with 6 20a breakers and 6 duplex Edison on the rear.
- Large Distro: I am looking at 5-Wire CamLock in and then have it split to 3 Cali plugs with the possibility of L14-30 and Edison outlets (breakers equal to the plugs). How do I size up the main breaker?
With my CS63## plugs I am running 4ga/4c SEOOW, I know its overkill but I have a 250? spool. For the CamLocks I am looking at purchasing #2 or 2/0 awg Type SC cable.
How does everything look so far?
If I need to use bare wire tie in and they only have 2 Hots (L1, L2, N &G), what is the correct way to do so? Assume that I have my small distro with Cali Plugs.
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
