Fulthrotl
~Autocorrect is My Worst Enema.~
 - E
commercial office
3,000 sq. ft. slab on grade
wood studs, open ceilings,
minimal ceiling access in center hallway
no ceiling access in most of the offices.
6 A/C's in roof wells, 30 amp 240 3 phase
200 A 3Ph. 4 wire 120/240 delta...
100 amp single phase 3 wire sub panel
all conduit is 3/4" emt. no MWBC. 3 #12's
per home run.
1/4" x 2" x 2' ground bus in data room
ground bushing on ALL conduits, and flexs
too, for that matter... AC's get a ground bushing.
every.single.one.
#6 and larger shall be hypressed with imprinting
dies, for verification of correct crimp.
data and power home runs: 118. yes, one hundred and eighteen.
in slab.
6,500' 3/4" sch.40 pvc in slab. GRC yard ells coming out of
slab, taped.
200 data and power 4SD boxes total.
all lights are 2 tube pendant mounted wraparounds by metalux.
75 fixtures total. two pendant drops per fixture, most end to end,
and on sloping ceilings, dropped to 9'.
now, the swagging..... how many hours for the whole thing?
i could use some numbers to see where y'all think it would take...
bid time is 9 am tuesday morning......
thanks for any insite you can put on this.....
randy
per home run.
every.single.one.
in slab.
slab, taped.
randy
