mtnelectrical
- Essex, New Jersey
Does an electric Hot water switch box need to be painted in red? Inspector is asking for red box, as far as I know only apply to gas or oil appliances.
And if required to be red for the oil or gas appliance it is not an NEC requirement but may be by other codes. I think you usually see this for oil burning appliances, if there is an emergency situation they want the oil pump disconnect easily identifiable so the pump can be shut off to prevent continuing to pump fuel into the situation.Does an electric Hot water switch box need to be painted in red? Inspector is asking for red box, as far as I know only apply to gas or oil appliances.
