milemaker13
- Suburbs of Chicago
We are about to order a huge new press and I just want to make sure I have a few things right. This being the largest machine I have installed yet so I don't want it to come in wrong.
I am told the machine is 460v 3 phase and it was noted that the main motor is a Y- configuration.
Our building has about 492 volts phase to phase, and has a neutral. Our lighting ,for example, is 277 volts. I assume this is a 480 Y system, correct?
Rule of thumb has always been 10% so the machine should be OK with up to 506 volts. But nowadays new equipment will sometimes have a lower tolerance.
And would it matter if my building was 480 Y or delta? Does this mean the machine will require a neutral connection? Why would they specify the motors being Y wound?
I need to see if I can get some better info, but this is what I have so far.:?
