- NE Nebraska
The 'dummy breaker' space filler (QO1DB) has a flat front.
Which I believe there is some of those in the panel pictured here also.
I noticed the new dummy breakers also have a blank front. I was thinking that as a first generation thing they might have used parts that were already in production.They look like this.
Can you get a picture of the internal wiring? How about some better quality pictures of the breaker with no handle?More pictures:
Where do they mark the size on the slotted type? The rotating key style has the size stamped near the keyhole.The original key operated breakers had a key that looked similar to the key for light switches. The key was inserted flatwise into the breaker.
Isn't the one below just a partial view of a 3-pole breaker? See the wider shot in post #16.You are correct.
In picture #2
http://i.imgur.com/x2UA3.jpg
There are both dummy breakers (below the key-operated breaker) and normal blank fillers (just above the key-operated breaker).
Dummy breakers do not contain the words On and Off.
Maybe, can't really tell. But, it is still what a dummy breaker looks like.Isn't the one below just a partial view of a 3-pole breaker? See the wider shot in post #16.
I don't quite go back that far.These pictures are from a panel that went obsolete back in the the mid 60's. 50 years ago there was no code requirement that the rating of the breaker be visible when the breaker was installed.
