mjf
Anyway to tell for sure what a jumper bar in an old meterbank is rated at?
they go from load side of meter to line side of main disconnect.....Breaker snaps right on to jumper bars.
Doesn't the label indicate max circuit breaker allowed? That would be the designed rating.
Yeah, I did look for the label. Seems to be MIA.
Well I would guess that they are 125 amp rated if typical plug on miniature circuit breakers is what is used, but there is some chance they could be limited to 100 amps. Is not likely they are limited to any less than 100 as there would not be as much demand for one designed for less than 100.
Is there manufacturer and model information available, that would be a big help.
Zinsco breakers! They need to be rated 1 gigaAmp:happyyes:
