NM in carport.
NM should be OK because the carport is normally dry location. (well it depends which location of the carport and how much it rains in your area)
But FWIW, I would install the UF cable.
What edition of the NEC are you citing?
2011 NEC
334.12 Uses Not Permitted.
(A) Types NM, NMC, and NMS. Types NM, NMC, and
NMS cables shall not be permitted as follows:
(1) In any dwelling or structure not specifically permitted
in 334.10(1), (2), and (3)
I do not call a carport a storage "building".
OK. You changed my mind.
ICC
BUILDING. Any structure consisting of foundations, walls, columns, girders, beams, floors, and roof, or a combination of any number of these parts, with or without other parts or appurtenances.
"a combination of any number of these parts"
foundation and floor = building:)
I think a car port qualifies. Whether it is a damp area or not is something else. Since a covered porch is considered outside and thus damp, I am thinking a car port is as well.
I really don't see how a carport is not a damp location. If it is exposed or if the nm is run in conduit than UF- IMO. Of course most crawl spaces are damp and I have never seen nm affected by it-- I think NM should be rated damp location
