stevephillips
- knoxville tn
Was called to a church because light bulbs were burning out very fast. I show up and start asking my basic questions, (new problem, old problem, any new work, bad smells, etc..) They decided to demonstrate by putting a 75 watt incan in a lamp and turning it on. It burned out in about 1 second with a bright flash. Plugged into that same outlet was a computer, and some other officey equipment.
Went outside to get my fluke and looked up the pole and saw 2 pots, one big and one small. Hrmmm, open high leg maybe? Well, long story short, the buildings service is high leg delta. Outlet was putting out 208 volts.
Upon asking more questions, and speaking with the resident electrical "expert", the office needed more circuits so he added them. He found that every third slot was free and decided to use those.
The scary part, its been like this for over 2 years. The reason the computers didn't burn up is because they had universal power supplies (100-250 volt, 50-60hz) so 208 was right in the range. Its a good thing they never plugged a space heater.
I never could convince the resident "expert" that 240 phase to phase, 120 phase A and C to ground and 208 phase B to ground was normal. I ended up installing a sub panel with all the new circuits added to it.
Thought you guys might find this interesting.
