Anyone have a wiring diagram for such an arrangement, using 2 relays and 3 capacitors of rating 200, 60 and 20 microfarad, for a 3 phase motor on an old lathe?
The owner has replaced one relay that was permanently energised with another relay, but the new one gives the same symptoms i.e. it remains enegised but the motor doesn't run at all now. The original fault was that, the motor could only be stopped by switching off the 230V supply. One of the relays appears to be a fleeting start to switch the other capacitor to get the motor running.
Regards
Regards
