shamsdebout
- Macon,GA
What time delay are you setting for the occupancy sensors you are installing?
I like 15 minutes.
I like 15 minutes.
Thanks for the responses. Always good to see what others are doing.
We do have a client who is very adamant about his sensors being set to maximum sensitivity, maximum time delay and disable walk through and photo sensitivity settings.
Depends some on the usage of the room.
You don't want someone to enter the far stall in a restroom and have the lights go out while they are still in there:happyno:
I may be wrong but doesn't number of lamp starts effect lamp life? What costs more, a few extra minutes of "on" time or more frequent lamp replacement? It would really need a more involved study to find the average "on" time, number of starts, and effects on lamp life, and then factor in cost of energy and cost of lamps to really know which is best.
Of course the "green" people will say do what ever uses less energy no matter the cost.
Some peole are not all that open about some things and try to be quiet in the restroom, but I guess the microphone idea would still work when they holler "Hey, who turned off the lights":happyyes:If you're using T8s they are probably instant start so starts certainly affects lamp life. Sensor Switch, one of the only companies that I actively promote, makes wall switch sensors that are supposed to regulate the voltage in such a way to limit premature lamp failure. The sensor guys; Leviton, WattStopper, etc; seem to think 10 minutes is the ideal range. If the area is little used, like a broom closet, you might want to shorten it for just a couple minutes.
If you're concerned about situations with the "far stall" or unseen areas might a suggest a Sensor Switch WSD-WH-PDT with a little microphone in it?
I have never specified the sensor switch product. How do you compare their technology to a WattStopper dual tech sensor?
There's no question, Sensor Switch is better. It's easier to install. It doesn't require a ground wire. It doesn't require a neutral. It comes preset to ten minutes.
You do still need to install them don't you, you sound like a used car salesman.You make it sound like all you have to do is throw it at the spot you need it and it will stick when it hits and you are done with the install:thumbsup:
Now you are talking about the wireless technologies.
you still have to do alittle synchronizing after you throw it against the wall.![]()
TNBear, what would you suggest for maximizing lamp life on lamps that are almost always lit,but are cycled hundreds of times a day with the off time per cycle being only a few seconds?
It seems like a odd situation, but that's what goes on for interior lighting for electric rail cars. As the pantograph go over non-electrified zone or there's a jump in connection the lights go off briefly but stays. I'd guess 16-18 hrs a day. Lighting does not have ride-thru UPS. The trains run on 600v DC, but not sure what lighting runs on
I suppose that wear and tear on lamps are comparable to 5-10min/cycle usage.
Programmed rapid start or LEDs?
