I found this problem at work my suppervisor is not an electrician and I want some feed back for him.        There is a metal conduit with 10-18 # 10 thhn wires in a slab,they come into a metal box and branch out in runs of emt.One of the circuits kept triping the breaker until more than likely burnt in half. what should be done to fix this.
A) pull all the wires out to check them and replace the broken one
B) pull only a new wire in to replace the one you know is damaged
C) abandon the broken wire, run a new conduit, pull new wire to replace the damaged one,and do nothing to the rest of the wires.
Forgot to mention its a two part question. Does any of this create a hazard where some one could get hurt.
I would run a new conduit and replace all the wires, or pull all them out check them, replaceing the damage ones.I think there could be more than one damaged which could energise the conduit.
