Is there any harm in the EGC of a circuit(pool light for instance) being connected to the bonding grid? There is no way to keep one isolated from the other since the terminations in the light junction box are connected together physically in the design of the box. The bonding lug on the rear of the wet niche fixture(#8 solid connection) is once again physically joined to the lug on the inside of the housing that accepts the #8 insulated running back through the PVC to the J box. The pool heater is another example where there is an external lug for the #8 solid on the sheet metal housing and also an EGC termination in the wiring compartment. I've asked a few inspectors and seem to get a different answer each time. I know the intent of the bonding grid is to eliminate voltage gradients, but does the EGC being tied in adversley affect it in any way? Thanks.
