clintryan
New member
- citrus heights,california
Are push on style breaker load centers OK in commercial builings? And where,if at all,does it talk about it in the code book.
Load center push on breaker unlike bolt on; is what I think he is asking about.
If I recall Pushmatic are bolted in.
I think you are correct in that the OP is talking about push on vs bolt on breakers. Generally speaker commercial jobs use bolt in but that is usually a spec by the engineers rather than a code issue. I did a small retail store and used regular push on style breakers.
Yeah, it's just a engineer or customer spec unless a higher AIC rating is required. Square D makes a panel (NQOD) that takes either type. They also make a 277/480 volt panel that does the same, I think it is a NEHB designation? But have rarely seen plugins used in it.
