If you understand isolated ground each IG receptacle shouldn't share anything. Dedicated hot and neutral to each IG receptacle and the IG conductor goes back to the service entrance, not a sub panel.
Fortunately IG circuits are rarely needed today and are a waste of money.
-Hal
absolutely correct. unless you had an isolated ground bar in the panel, insulated from the can
 connected to a seperate earth ground. there is no such thing. we get drawings all the time showing isolated ground recp and thats it. the riser is no different. still one ground for the service. the truth is a ground is no different that any peice of bonded metal in the entire building.
