esc1234
- Kansas City
I am sure that this has been asked, but I searched to no avail. A new structure has been built, all steel framing. I am grounding my service to the buiding steel, also there is a water pipe available that meets all of the code requirements to be a grounding electrode. My question is will I meet code if I bond to buiding steel with a conductor, then jumper from building steel to the water pipe or do I need two seperate condustors, essentially creating a paralle path to ground? Thank you in advance.
