GerryB
 - woodbridge, ct. USA
I just installed my first interlock for generator back-up after hearing a lot about them, all good. I had a few concerns though. On the good side I found a site, National Ram Electronics, that has a whole line dirt cheap. I paid $39.00 no tax or shipping for the one I needed and they were all about the same. The Interlock Kit site wanted $150.00 This one was a half inch thick piece of plastic with a thru bolt that allowed it to pivot. My concerns were the power inlet box I installed is the one with the twist lock prongs exposed underneath, so if someone removed the panel cover and turned everything on and maybe didn't put the cover back or removed the interlock bar you would have exposed live wires. The kit comes with postage stamp size stickers warning not to turn the generator breaker on if the main breaker is on, so I guess that covers the electrician. And obviously with the panel cover on and the interlock installed properly this can't happen.  My other concern was this was an old panel with a Bryant main breaker. It was fairly hard to turn off, (probably hasn't been thrown in years) to the point where I was hoping it would go back on. Now I'm worried HO might have a problem with it. Anyone had any callbacks or problems with these? Thanks.
