etbrown4
- United States
We've installed a number of whole house generators. In the past, Generac has provided a pre-wired gen panel with circuit wires already attached to breakers and has provided one neutral connecting the gen panel to the main panel.
The latest unit we bought has a separate neutral wire for each 110 v circuit and is labeled with "neutral circuit#1, #2" etc.
It appears that Generac suggests that you attach the neutral for each 110v circuit in the gen panel to the actual neutral wire for each 110v circuit picked up in the main panel. In other words they want you to remove each affected neutral wire from the neutral buss and attach it to the individual neutral coming over from the gen panel.
Anyone know why they might have adopted this change? Does it make prior gen panels unsafe or non code-compliant?
What's the difference between 12 individual neutrals vs a larger neutral used in the past?
What's the difference if those 12 neutrals are connected to the neutral buss in the main panel, vs. connecting them separately to each individual neutral in the main panel (after detaching those neutrals in the main panel from the neutral buss)
