Alwayslearningelec
- NJ
- Estimator
If you installed a 20 ckt and there was a change to remove the ckt because the equipment was removed. What would the normal procedure be to remove the circuit......disconnect wire from breakert, pull wire all the way out or just to a box??? etc... Thanks.
