ohmhead
- ORLANDO FLA
Well heres my question if you have more than three conductors in a raceway lets say  the current in each conductor  is 3 amps  there connected  to  20 amp breakers  in panel  .  How does this effect size  of  the breaker at 20 amps  with a low demand of 3 amps per conductor would you use a smaller breaker or would  load  diversity   the demand  factor of the load  keep the breaker at 20 amps .
explain load diversity lets say at 50 percent of the breaker size is there a rule to reduce the size of the breaker .
Meaning if the conductors pulled less current then could you install more conductors in a raceway and reduce breaker size to protect them .
