AV ELECTRIC
did not see a troubleshooting  forum so i elected to post here replaced an evaporator cooler motor 115 volt dual speed high and low old one burned up receptacle  replaced motor  and receptacle the motor is half horsepower.
when motor is turned on high speed or low the rpm is the same and motor over heats and trips the thermal overload tried different circuits same rresult
this is in a residence rural location 200 amp service 1987 challenger service
the pump for the cooler works fine the fan and belt seem to work freely cranking by hand and actually removed the belt and let motor free spin and still seemed to overheat but did not trip overloads but of coarse i am only running it for a short duration no problem in the rest of house no
flickering or unstable voltage no burned up neutrals in service
could there be a problem with the service voltage is good 120 volt no drop when running the unit it almost seems like the motor is acting like it is
running at a lower voltage but i am not seeing it on the meter and like i said tried multiple circuits same result
any thoughts would be appreciated
