In 1965 it said that, ".....shall be constructed of brass or bronze unless located not less than 4' from the pool."
So I'm taking that to mean that if it was brass or bronze that it could be within 4'.
Thanks, I agree. And I would assume that it was possibly the same, or less stringent, in 1962. But, I'm hoping someone can answer definitively.
A little background..., An unknown electrician started this job, and he, and/or the pool owner crossed swords with the inspector. A second electrician was called in and the inspector is being
very thorough. Second electrician was turned down because the existing junction box he utilized for new low voltage pool lights was within four feet of the pool. Apparently, building official records indicate that the pool was installed in a time period that fell under the 1962 NEC. The inspector apparently told the electrician that he would accept if 1962 compliant.
I'm attempting to find out if the box is brass or bronze. I would guess it is, if it is still there after all these years.
I was simply asked if I had a 1962 code book, that is how I got involved. Just trying to help if I can.
Thanks to all that are attempting to find me an answer.
WC
